XM Satellite Radio?
Can you still listen to your factory radio?
Is the install clean - pics??? is it wireless or require hooking into back of stock HU?
Do you need an external antenna?
How much should I pay for the unit and install? Any other costs besides the monthly subscription?
Also considering for a 323i, if anyone has any experience or pics ...
but yes you can still listen to regular radio broadcasts. My install is flawless with the Blitzsafe adapter; it connects the receiver in the trunk directly into the CD changer cable...no need to remove the head unit. To listen to XM, I just push the CDC button on the HU. Set up like this, the install is cake and you shouldn't pay anyone to do it. External antenna is required to pull signal but you can put it inside on the rear hat shelf if you like. I'm fine with it on the trunk.<ul><li><a href="http://public.fotki.com/boosted/automotive/xm_radio/">XM pictures</a></li></ul>
you'd have to put a switch adapter in between, and run the switch up into the cabin so you could select which signal the CDC button takes. It wouldn't be a huge deal, I know someone has done it to run an iPod and changer through that cable...I just don't have a desire for a changer so I haven't looked into it.
If you had to pick a receiver w/CD and Satellite Radio capable under $200 which brand from these....
CTA4AVANT
01-29-2008 07:29 PM
Steve_Ag Arrow
9
11-19-2004 08:30 AM
DLow
03-14-2003 05:36 PM
Nogaro S4
02-24-2003 08:53 AM
