****Havin a little trouble
bolt back on as one whole piece...bracket with snub in the basket then mount. I had the same issue.
I spent a few minuted wrestling with the damned thing before I realized that I only had the snb 1/2 way on !
It should go on quite nicely if you have it properly fitted to the support arm.
then shove it all the way on...that should work. If that bracket doesn't go back on easily, then the snub's not fully on the bracket arm.
then screw in the bracket and tighten it. Then start the car, rev a little to get the snub and basket settle in. shut off then tighten basket. Restart car to see if there is excessive vibrations when at idle.
