*Ack* Need someone with a Bentley ASAP! Took ashtray out and now can't get it back in!!
Old 07-30-2002, 05:43 PM
Member
sohcrates's Avatar
Default *Ack* Need someone with a Bentley ASAP! Took ashtray out and now can't get it back in!!
<center><img src="http://mywebpages.comcast.net/thad46/ash.jpg"></center><p>Trying to install my XM radio controller. Stupid ashtray won't go back in.
All i did was remove cover around Tip shifter and took 2 screws out....ashtray kinda came out...but now won't slide back in!
Can anyone help? I'd like to finish this tonight!!
Old 07-30-2002, 05:48 PM
Member
Big D's Avatar
A hammer will do the trick...
Old 07-30-2002, 05:50 PM
Dustin A4's Avatar
Default Searching Archives.....maybe this will help.....
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/112404.phtml">https://forums.audiworld.com/a4gen2/msgs/112404.phtml</a</li></ul>
Old 07-30-2002, 05:53 PM
A4-Freddy's Avatar
Default Everything Bentley says about the front ashtray..
<center><img src="http://pictureposter.audiworld.com/34761/ashtray.jpg"></center><p>..it ain't much, but from the instructions and pic it sounds like you were supposed to remove the auto tranny cover and lever, I'll post that procedure in a second:
Front ashtray, removing and installing
1 - Front ashtray
Removing
- For manual transmission: Lever out shift cover upward and remove shifter boot
- With automatic transmission: Lever out shift cover upward
- Remove two bolts -2- at ashtray.
- Remove ashtray -1-.
- Disengage trim -3- from ashtray -1-.
- Unclip storage compartment trim -4-.
2 - Bolts (2x)
- Tightening torque 5 Nm
3 - Ashtray trim
4 - Storage compartment trim
Old 07-30-2002, 05:54 PM
Member
sohcrates's Avatar
that looks like a great start! thanks! trying it out now. wish it wasn't so muggy outside!!!!
Old 07-30-2002, 05:55 PM
A4-Freddy's Avatar
nevermind, if you follow dustin's links you'll see the tran **** cover procedure too
Old 07-30-2002, 05:56 PM
A4-Freddy's Avatar
you fast forrest... those mad skillz again
Old 07-30-2002, 06:00 PM
Dustin A4's Avatar
Mama always said, search the Audiworld database before you post your question.
Old 07-30-2002, 06:01 PM
Member
sohcrates's Avatar
Default DAMN. This sucks. all i wanna do is get the stupid thing back in....
instructions seem to say how you can remove it, and you'd assume you could just reverse it to put it back in
i try to "slide" it back into place but it keeps hitting something...might be the foam insulation down in there i guess
think if i take it to a dealer tomorrow they can just pop it back in for me?
this SUCKS
Old 07-30-2002, 06:03 PM
A4-Freddy's Avatar
you removed the shifter stuff per the instructions too? not sure why it says to do that..
Quick Reply: *Ack* Need someone with a Bentley ASAP! Took ashtray out and now can't get it back in!!
