^%#$#@#^%#&&!!!! Glove box door hinge snapped. ^%&^$$%#%#!!!!!
I searched and noticed this is a very common problem. We should get a petition together to approach Audi USA and demand they own up to this major design flaw and offer a fix for it. You pay close to $30k for a premium vehicle and you'd expect the simple things to not break so easily. Geez, I'd bet a friggin Kia never had a problem like this.
Anyway, I'm out of warranty and my CPO warranty doesn't cover it. So I called the parts department and and they wanted over $300 for a new door. Even searching the 3rd party Audi parts suppliers the best price I could find was around $200. That's a pretty ridiculous price for what amounts to not much more than a plastic panel with a hinge on it. $2.50 in materials cost tops.
Either way, for the short term I'm going to try and glue it back, and maybe drill a dowel hole through the hinge and the panel and insert a small metal pin or something to reinforce the glue joint.
Does anybody have suggestions for the best kind of glue to use? I once used a two-part epoxy on my old A4 to glue the arm rest door hinge that snapped off, but that epoxy never lasted. The glue, once fully cured, was too brittle and the joint would eventually fail again... and again. I had to keep re-glueing it several times. I wonder if there's a better glue that maybe stays a little more flexible and grabs onto the plastic a little better. Any suggestions?
Also, for anybody who has repaired or replaced their glove box door, do you have a writeup on how to remove it?
Thanks
Thanks
That door is eXpensive everywhere. Cheapest place I could find was ClairParts and it was still like $250.
And the way it's made, it's almost impossible to fix. Unless you can fibricate something from metal.
Check this DIY (with pics).<ul><li><a href="http://forums.vwvortex.com/zerothread?id=2359362">http://forums.vwvortex.com/zerothread?id=2359362</a</li></ul>
In fact, one guy I called started laughing... he was like "good luck finding that... they are always getting inquiries for that item..."
Great.
Great.
