'02 A4 1.8t Turbo lag or Transmission slip?
#11
#12
I have the 034motorsport silicone PCV hose coming and the 3 way valve too. I went ahead replaced the valve cover gasket since I was in there as it was seeping at the rear right corner and discovered my plugs are wasted! I guess the guy who owned it before me never changed them, LOL.
Not good, What would cause this?
https://drive.google.com/file/d/0B2i...it?usp=sharing
#13
If anyone gives a ****,
I replaced all the PCV junk with the 034 silicone kit, replaced the 3 way check valve off the suction pump and a few more CV's. The Car is still sluggish from a stop and slow to get to 90 from 70mph. I did a boost leak test as per instructions from this site and put 10psi into the system and heard a light hiss coming from the suction pump and then before I could get to it, it blew apart. Am I right to assume that the turbo isn't doing it's job since the pump blew at 10 psi, it should have come apart during the drive if the turbo was working, no? I removed the pump and plugged the manifold line and there were no leaks at 15psi. I'm just hoping it's the Turbo and not the trans.
Phil
09-16-2004 11:36 AM
