02 A4 B6 1.8T FWD Adjustable Clutch Linkage? Is there a way to adjust anything there?
then the 2 gear-box mounts, for excessive play, wear, etc...
Next check the shift linkage for wear, excessive play, etc...
Ya might want to try and adjust your shifter & linkage, if the above items show no signs of wear.
put lithium greese on all the moving parts. There was lots of hardend white greese chards/chunks in the shifter pan at the bottom below the shift connection. I test drove it with some difference. I will see if the greese works its way in a bit more with use.
How exactly do you "adjust" the hex bolts to make an improvment?
It may not be adjusted correctly?
Follow steps 6 to 10-<ul><li><a href="http://www.goapr.com/Audi/support/b6_snub_mount.pdf">http://www.goapr.com/Audi/support/b6_snub_mount.pdf</a</li></ul>
ECS Tuning-Audi
11-08-2017 08:59 AM
Audi A6 2005 allroad 2.7t 6mt
mzguy
14
12-31-2015 06:28 AM
ECS Tuning-Audi
Audi A3 / S3 / RS 3
09-25-2015 11:30 AM
