03 3.0 Crankcase breather hose broken causing missfire?
Just replaced spark plugs, coils, valve cover gaskets, and resealed lower oil pan. Started car up and it was missfiring bad. Got codes p0300, 302, 303, 304, 306 (300=multi missfire and the 2, 3, 4, 6 are specific cylinder) and 0441(evap system, incorrect purge flow). So I went so far as to pull all spark plugs back out and double check everything which looked good and put it back together.
Started it up and had a missfire again this time with codes 300, 301, 302, 305, 306.
The only thing I could find was the crankcase breather hose on the left side(driver side) attached to the valve cover was broken(seperated in 2) right at the flexible part. Will this cause a missfire? I don't know if the hose was already damaged before, being that I just noticed it. Would appreciate any help. Thank you
thus causing misfire.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
audijim113
09-03-2015 01:22 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
