03 A4 1.8T GIAC IBE released.
Overview of pricing:
Stock chip (actual stock chip) plus 1 performance program: $695
Stock chip (actual stock chip) plus 2 performance programs: $795
Stock chip (actual stock chip) plus 3 performance programs: $895
Stock chip (actual stock chip) plus 4 performance programs: $995
Performance programs available:
Premium Fuel Street
100+ Octane Race
Valet (30mph speed limiter)
Ignition Kill (security)
These prices are *not* in addition to a non-IBE GIAC chip, these prices are for everyhting needed to install an IBE in an ECU.
There is a full trade in discount if you already have a GIAC non-IBE chip for this vehicle.<ul><li><a href="http://www.awe-tuning.com/pages/shared/part_detail.cfm?PMaI=1&PMoI=27&PEI=2&P P=8e_a4_18t_chips.cfm&PPT=Chip&IL=GIACIBE" >GIAC IBE from AWE</a></li></ul>
Premium Fuel Street
100+ Octane Race
AudiWorld Expert
Question about the "Ignition Kill" ...
Is it really a misnomer since the true meaning of ignition kill would not allow one to turn on the ignition.
From what I hear, while in "Ignition Kill" mode, you can still turn on the engine, but it will stall shortly after.
My concern is that I've heard numerous cases of car throwing a CEL and running rough if you accidentally turn on a cold engine and shut it off right away without letting it warm up at least a little. If you forget that you're in "IK" mode, you're going to cause just that.
I'm not sure I understand your point:
It does kill ignition (spark). The "ignition" key is called that because it starts the ignition of fuel process of the engine.
No reports of the CEL or misfiring after using the security kill program, either. I understand your concerns, but this is not an issue.
Todd - two questions -
1)once the ECU has been modified, can the chastity belt be "reapplied" to make it "look" like it's been unmodded?
2) is the IBE "coded" similar to a garage door opener? in other words, will any IBE switch work with any IBE?
TIA
TIA
