1.8t coolant leak and misfire on cylinder 2
Car begins to overheat when driven. I can keep it running in the garage with no coolant leaks. Two issues I’m facing is a misfire on cylinder 2 and a coolant leak. I replaced all recommended parts suggested from others with no luck. Attached are two videos, one showing the misfire from the exhaust and the second showing where I’ve caught the culprit of the coolant leaks. Please is you have any suggestions or can tell me what the part is the leaks coming from it’d be really appreciated!
Marcus, in general you coolant leak could be from a multitude of places, even though there is no video, ill make the assumption that the location isnt obvious and right up front? In which case, check the coolant inlet phalange around the back of the motor, top of the head. There something about the vibration of the road that promotes this activity to occur
Corey
12-08-2005 07:02 PM
