1.8t O2 Sensor Question...
I've been searching around and trying to figure out something I think is simple.
The pre-cat O2 sensor (S1) is self heating and the post-cat O2 sensor (S2) is not heating? I have a bad S2 and I'm trying to figure out what kind to get for a replacement.
Thanks in advance!
Thanks in advance!
for the post cat o2 sensor:
4 wire = heated
2 wire = not heated
the audi is really touchy but you could just bust out the ole 89-92 ford mustang 3 wire or find a similar 4 wire they are like $40 at autozone. in a pinch; or get the chip that deletes the this diagnostic sensor (yes it is used only for diagnostics of the cat) and the chip ignores it; and the missing doohickey that usually sits between them and is replaced with a crack pipe![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
o2 sensors 80K warranty, federal law
4 wire = heated
2 wire = not heated
...<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=7012">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=7012</a</li></ul>
I know its a little late, but thanks for the info. Turns out it wasn't a bad O2 sensor. I ended up changing the speed sensor, cleared codes and its been running fine since.
vansoffyomama
09-28-2015 04:38 PM
ECS Tuning-Audi
09-25-2015 01:20 PM
ECS Tuning-Audi
09-25-2015 11:51 AM
