2002 Quattro - Reverse Shift Noise
Just bought a 2002 Quattro. When shifting into reverse from park, it makes a clank noise. Other than that, car is great, no noise in forward gears. Anyone know what might be the problem? I am taking it in, but would like to know if anyone else has had this problem. Hopefully, just a small adjustment.
This is what I was told when I owned another manual transmission car. Just shift a little slower than normal when you go into reverse, and there shouldn't be much clunking noise.
shift? Many people, with both automatics and standards, shift into reverse with the car rolling forward slightly, which can cause noises/problems.
does it happen only when you turn on your car and then shift from park to reverse or also from park to drive? If it happens under those two scenarios only then that is your ABS engaging. For some reason it is more noticable on our car than on any other I have ever driven. It scared me too when I firsted picked up the car.
Avantadrive_Original
A4 (B7 Platform) Discussion
09-14-2015 12:11 PM
Audi A6 2002 Audi A6 Quattro DIY Special
SpedhedEd
09-10-2015 06:02 AM
