2004 tire pressure on standard tires
My fiance has an A4 that came standard with 235/45HR17 Eagle RS-A's. When I checked the tire pressure the dealer put them at all four were at 41psi cold. She usually drives the car alone, with little bagage. Per the door placard the tire pressures should be 30psi cold for all four. I dropped the press in all the tires, but now she says the tires squeal much more often than before. Am I missing something? Should I put the pressure back to where it was?
Any words from experience would be much apriciated.
if you have a tire go bad, you will have a hard time getting them to replace it if you run pressures that are higher than the recommended levels.
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
stormchaser1967
09-02-2015 08:48 AM
