2005 infiniti G35 - 298hp, 6-speed - AWD
Old 11-28-2004, 03:19 PM
  #91
New Member
2003 A4 1.8t girl's Avatar
Default Re: JERK, Call me hunnie again, I'LL RIP OFF YOUR HEAD
Go back to your german appliance grocery getter Jetta
Old 11-28-2004, 03:20 PM
  #92
New Member
Default Re: THEN THEY ARE STUPID LEMMINGS
bottled water too.
  #93
New Member
Re: I'm Not, Car & driver says G35 #1, A4 # 5
Old 11-28-2004, 03:21 PM
  #94
New Member
Default Re: YOU"RE AN IDIOT, that made no sense at all.
German auto brand snob? that's all I get from that. That is BS.
Old 11-28-2004, 03:22 PM
  #95
New Member
Default Re: Another Fool heard from
like sheep you are
Old 11-28-2004, 03:40 PM
  #96
Jet Jockey/A4 Pilot's Avatar
Default Sure...
EDL controls left to right wheel spin.
TorSen controls front to rear torque split.
If the ABS/EDL sees a differential in speed between a right or left wheel, it will apply the brake on the wheel with less traction thus transferring torque to the one with more traction.
If the TorSen senses a differential in speed between the front and rear axle it will shift torque to the axle with more traction.
I agree with you that the older generation Audis did have a mechanical lock and when in use they lost their ABS system IIRC.
I don't think by loosing traction on only one wheel the car would be immobilized. You would perhaps need at least two, one on each axle.
If a front wheel spins, the TorSen will see the speed differential and shift the torque to the rear and vice versa.
As far as EDL not being on FWD A4s, look again in an owner's manual. In my 1998 B5 Passat it was the only electronic aid available with ABS, no ESP, no ASR, no EBD. The system cuts out IIRC at 30 KPH (20 mph) on a FWD car. It will also disengage if overheated. So if you are stuck in a snow bank and try to pull out, it will after a while by the logic in its software disengage, so back to a normal car you go. The early model A4s had ASR which included the EDL. Maybe someone here on the board with a FWD model could look it up.
Today's VWs including the Passat, Jetta and Golf all have the ABS/EDL and ASR to help you under acceleration so as to not loose traction.
I can assure you that you can get all four wheels to spin on a Quattro, even on dry pavement. The guys who run lots of power on a FWD A4 will get lots of wheel spin too and the EDL will not interveen because of the speed at which it is happenning. Most guys that drag modofied B5 S4s bypass the EDL so that it won't rob them of a few tenth on the strip.
Finally I just wish Audi would give us a purely mecahnical limited slip diff, at least in the back.
Old 11-28-2004, 04:01 PM
  #97
ILMA_Revo_Stage_2+'s Avatar
Default Are you a spy for Acura/Infiniti? If u were a regular member your arguments would hold some
credibility. most of your responses have been copy and paste. with your limited post count, its hard to believe whatever it is your saying. have fun with the G35.
Old 11-28-2004, 04:03 PM
  #98
Default Oh yeah?
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/732786.phtml">Did you visit the Infiniti dealer yet?</a></li></ul>
Old 11-28-2004, 04:21 PM
  #99
A4xIV / Nadroj's Avatar
Default they are totally different cars. acura and infiniti does not come close to
what audi bmw and mercedes does. They try to imitate a luxury vehicle, while they fail miserably. You can tell as soon as you sit down and look at the cheap interior.
Old 11-28-2004, 04:22 PM
  #100
satanA4's Avatar
Default The G gets about 330 miles/tank .....
where as my A4 gets aroud 425/tank.
Quick Reply: 2005 infiniti G35 - 298hp, 6-speed - AWD
