235/35-20 or 245/35-20 on 20x8.5? Anyone with experience + lower then OEM Sport?
#21
I wanna see ![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Yeah, 235/35-20 would be safer. I had asked Chris for his opinion, but no reply. I'm sure he would mention this one though.
Maybe I shouldn't venture into 20 territory though with the wheel problems I have had. If they were to rub, I'd go crazy and drive off a cliff
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
#24
<center><img src="http://pictureposter.audiworld.com/32791/cimg1208.jpg"></center><p>I would occasionaly rub on the outside and i had to shave the uprights slightly on the inside. Lowering the car over them seems almost impossible.
#26
AudiWorld Expert
235/35/19 diameter: 25.5 inches (your current tires)
235/35/20 diameter: 26.5 inches
245/35/20 diameter: 26.8 inches
So like I said, you'd be adding a whole inch to the overall diameter.
And that is why TireRack's recommendation is better because:
245/30/20 diameter: 25.8 inches.
#27
Too scared
Dimensions can vary from brand to brand though, from manufacturing process. My P4's were much closer to 25" dia. from measuring them, and that was w/ them inflated to 38 psi. Only way to be sure is actual measurements from manufacturer.
#28
just how much of it are you willing to tolerate. I don't mind the rubbing in the rear w/ a full load on bumps and dips as this occurred w/ the RH's But the Rubbing in the front would drive me nuts...but i dont think that will happen. From what I heard the guys over at autosport werks just removed the screws at the top of the liner (doubt it was that easy) but yah.
No dont have the tires on yet...maybe end of this coming week.
Hell too bad toyo doesn't make a 225 35 20 then it'll really get closer.
#29
but you know how obsessive I am with perfection ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Rubbing from the rear tires with that kind of situation is ok. But it's the rubbing up front from small dips and while turning that kills me. But that is being caused by the 5mm spacer I had to use. Other then that issue, I've never had any rubbing problems with my 19x8.5 ET31 w/ 235/35-19 set up - even as low as I am on CO's and with two extra passengers.
If the 235/35-20 tire is going to be almost 1" bigger in overall tire diam. though, that kind of worries me. We need a 20" tire that maintains the 19" tire dia., but loses the profile to accomodate the 20" wheel. But then were riding on "rubber bands".
Lil Tiger
A4 allroad (B8 Platform) Discussion
10-21-2020 02:23 PM
old-dog
Chicago Discussion
11-28-2016 04:12 AM
Pmpsch
Q7 MKII Discussion
14
12-06-2015 01:14 PM
Yoshimura
09-30-2015 06:20 AM
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
