3.0 rough idle ???
Has anyone else experienced an intermittent rough idle on the 3.0? The check engine light is not on and the dealer can't find anything wrong. Any ideas? Thanks.
the 2003s, and some people with 2002s say they never have a rough idle with the 3.0. Mine always has at random times - seems like when the engine is cold or at least for a few minutes after starting.
I did start noticing recently with VAG-COM that I have some random misfires occuring in cylinders 3 and 4 when the idle is rough. I'm suspecting it's from starting-to-fail ignition coils.
Same situation. Dealer claims nothing wrong. It seems to happen more when it is hot out or I just ran the car hard. The only thing I can try and do is find a consistant situation and describe it to the dealer so they can create it. Other than that I am clueless. Without an LED warning my dealer says there is nothing wrong.
if it's not the coils (since it's done it since day one, it probably isn't), then I think the ECU is just over-doing it with trying to keep emissions to the absolute minimum. It's trying to hit a perfect balance with the idle mixture, and it's just not possible sometimes. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
For 2003, they probably changed the way it handles idling.
I'm wondering if your dealer called the Audi tech line to see if this is a known issue, etc.
Who knows, if enough people complain and it's just a software thing in the ECU, maybe Audi will issue a software update that dealers can flash the ECU with. But, there has to be complaints for that to happen.![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I'm just not sure if the rough idle could be partially caused by all these crap ignition coils. Without knowing what is failing in the coils, it's hard to say if they work perfectly until the point of total failure, or if they operate poorly before that as well.
