3.0 Vacuum line problem
Old 05-25-2010, 07:58 PM
  #11
MB-262's Avatar
Default Back to diagnostics
Originally Posted by Stephen Kormilo
I created a pdf document of the Vacuum Diagram from the info in my Bentley, which I have attached to this post. It looks like the hose should go to one of the Secondary Air Inlet vacuum valves (#4 on the diagram). I'm not sure what effect this valve might have on the performance of your engine, but it has to be there for some reason. HTH
Greatly appreciated for all the help. The CEL came back on the other day after two weeks of good engine performance, so now I will be replacing some more lines. Good to have the diagram.
Old 05-25-2010, 08:48 PM
  #12
Stephen Kormilo's Avatar
You might want to find someone with a code reader (VCDS would be best, IMO) to determine what is causing the CEL to light. This should help you in your troubleshooting.
Old 05-31-2010, 10:10 AM
  #13
MB-262's Avatar
Default More lines replaced
I went to my local Audi and the service manager that I've known for years was kind enough to check the codes. That's when I started to replace all the vacuum lines. Thanks to the diagram, I found where the rest of the lines went to, including the one that I clearly should not have plugged. A few scraped fingers later, I just have one last line to get. It's amazing how crispy these lines got and how they hide below other stuff. What a nightmare to replace this crap.
Old 09-06-2019, 11:20 PM
  #14
rumenski's Avatar
Just to answer the OP and perhaps anybody else who may be reading this later. The highlighted line leads to the passenger side kombi valve on the back of the head. It Y-splits into the shutoff valve on top of the motor and to the driver's side kombi valve. Cheers.
northfork
14
06-21-2020 11:56 PM
Telate
Q5/SQ5 MKI (8R) Discussion
04-26-2013 12:46 AM
Djole
Audi 100 / A6 (C4 Platform)
08-15-2005 06:50 PM
charles 200TQ
10-11-2003 05:51 AM
AlanBDahl
06-26-2003 10:04 AM
Quick Reply: 3.0 Vacuum line problem
