3 questions...how much is the pink coolant at the stealership(for my 1.8t)? 2nd question (more)
is there any other place i can find pink coolant(g12)3rd questions:my 2002 3.0CVT has yellow coolant and stealership claims that 2002 3.0 had yellow coolant. Who has yellow coolant in their 3.0?
ill let you know how much is costs. yesterday on the phone i was told i could use anything dex-cool apporved. then i called back from the parts store to double check, and they said dont use anything but the pink stuff we give you at the dealership. so im going this afternoon to get some.
<center><img src="http://pictureposter.audiworld.com/50842/121_2165.jpg"></center><p>It came in a 3:1 concentrate 1 L bottle (discontinued last I knew), and now only comes in premixed solution. It was around $6.70 L IIRC.
Same Organic Acid Technology. Exact same stuff. I changed to another coolant, Mercedes G-05 Hybrid Organic Acid Tech. Ford and Chrysler wanted nothing to do with GM Dexcool OAT, so they went (back) to the BASF Glysan G-05. Now GM is doing the same, dissowning their own product. G-12=Dexcool=blown coolant systems. Now, like I said your stuff could be any colour and be G-12...maybe Audi has switched to G-05 too??? Check if it is still G-12 with the dealer or printed on the coolant tank. I got a new rad and WP so I switched over, you just needd Generic Long-Life coolant like WalMart. If you add that or Prestone, make shure it is the new stuff. Water might be best if you need to add some now.
So does Ford, Chrysler, GM, Volvo & Saab. I wonder if the yellow stuff is not G-12.
