30K service
<i>
Engine Oil - Change the oil.
Engine Oil Filter - Replace the oil filter.
Cooling System - Check the coolant level. Add coolant if necessary.
Exhaust System - Check for damage and leaks.
Engine, On-board Diagnostic - Check diagnostic trouble code memory. Purge if necessary.
Doors - Lubricate door hinge mechanism.
Battery - Check electrolyte level. Add if necessary.
Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
Automatic Shift Lock (ASL) - Check operation, including park/neutral position switch (where applicable).
Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
Tires and Spare Wheel - Check for wear and damage. Check the pressure.
Service Reminder Indicator Display - Reset the display.
Brake System - Check for damage and leaks. Check thickness of pads and brake fluid level.
Drive Shafts - Check the boots.
Road Test - Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, and power accessories.
Lights - Check the lights.
</i>
</i>
Also, I had my 30K service done a couple weeks ago and there was no mention of changing the plugs on the invoice.
FYI, if anyone wants to see these service lists, create a "My Audi" account on the AoA website. On the homepage when you log in, there's an option for "Recommended Service". From there, it lists what's done at each service interval (This is also in your service booklet).
rjdoc74
Q5/SQ5 MKI (8R) Discussion
18
10-10-2015 05:47 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
09-25-2015 09:02 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-25-2015 08:57 AM
ECS Tuning-Audi
09-25-2015 08:20 AM
517
09-25-2015 05:24 AM
