8 year old belt, 32k miles?
I have a 2003 A4 1.8TQ with 32,000 miles on it. I know most people recommend replacing the belt around 70-80k but in this case the belt is still over 8 years old. Do you think its time to be replaced?
If it were my car I'd replace it ASAP. The belts do degrade over time and it's still cheaper than valve and piston replacement. Our engines are interference design.
Hanover, December 2009
• Mileage not the only factor
• Aging damages material
• Correct, up-to-date maintenance information essential
The correct time to change a timing belt depends not only on the mileage of the car, but also on the age of the belt, Workshops should inform their customers of this, advises ContiTech. "Long periods of non-use place just as much strain on a belt as regular operation does. Aging damages the material – no matter how much you drive," explains Helmut Engel, Head of Automotive Aftermarket at the ContiTech Power Transmission Group.
Replacing a timing belt at the proper time prevents costly engine damage. Decisive for the replacement, however, is not only the number of kilometers driven but also the age of the belt.
Many drivers don't realize that the mileage on the clock isn't the only reason to make regular trips to the repair workshop. Most second cars, city cars and convertibles are unlikely to reach the replacement intervals specified by the manufacturer, even after many years of driving. In Germany, over ten million cars are driven as second cars – just under a quarter of the cars licensed with the Federal Motor Transport Authority (Kraftfahrtbundesamt).
"In the last few years, some manufacturers have already started to change replacemnt intervals to take age into account, especially for timing belts. However, these changes are not indicated in the service manual,” explains Kai-Uwe Suppé, technical trainer at ContiTech. In order to perform maintenance in accordance with the inspection guidelines, repair workshops should therefore always refer to up-to-date information, otherwise they could be liable to pay compensation in case of damage. "Automobile businesses can obtain all the important information on diagnosis, repairs and maintenance via providers such as Autodata. The information available via such services is updated regularly based on the original manufacturer specifications. That way, the workshop is on the safe side," explains Suppé. If the manufacturer has not provided suitable specifications, ContiTech advises that timing belts be replaced after six years at the latest.![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
When changing belts, it is also highly recommended to replace all the relevant belt drive components at the same time. This provides greater safety for the engine. With OEM-quality kits containing perfectly matched drive components, ContiTech offers the right products for this task. The advantages for workshops are clear: there is no need to order individual parts, you can always be certain that the parts match the vehicle and type and administration for incoming goods and processing becomes a lot simpler. This saves time and reduces process costs. Using kits also provides mechanics with the best possible means of protecting themselves from possible warranty claims. Workshops can find the ContiTech kits in the online catalog at www.contitech.de/aam. They are also listed in TecDoc, the digital information system that supplies the vehicle replacement parts market and workshops with comprehensive data for purchasing purposes.
Originally Posted by ContiTech.de
Customers should be informed by workshops
![](http://www.contitech.de/pages/presse/pressemeldungen/2009/091216_aam/image_1_uv_dl.jpg)
the interval is 75k miles or 6 years whichever comes first.
when the car sits for long periods of time is actually worst than driving it everyday as the shaft bearing in the water pump and other roller bearings create "flat" spots.
So I took the car to get an oil change the other day, and I asked them to check it for me. The mechanic looked at it, said it looked fine and to wait another year to have it done.
You're a gambling man then. Good luck. Keep us posted on what happens over the next year. Will your mechanic cover ALL repair costs if something does happen?
For reference, my mom has a 2001 Lexus that also has the original timing belt and a lot more miles than my car does.
Friendly comments and advice:
1) I don't believe you can look at a timing belt and determine whether it is "good" or "bad". What I do know is there is a history of Audis and relatively low timing belt life. Just go Google the law suit regarding the subject. OBTW, I am not aware of a similar "issue" with any other current makes.
2) Since both Audi B6 engines (1.8t and 3.0) are interference engines, the ramifications of a broken belt are serious; bent valves and broken pistons. If you choose to fix, it will run you probably $3000 for the 1.8.
3) Bear with me on this one... Mechanics and doctors are similar; go see 2 of them on the same symptoms, you will get 2 answers. I bet if you went to an Audi / VW independent specialist in your area, they would tell you "oh yeah, need to replace as soon as possible".
4) Finally, if you decide to keep driving it and the belt breaks, don't go back to the mechanic that told you not to replace. That is your call as it is your car.
Advice: go get it replaced...and recommend your mom get the Lexus done as well so she doesn't get stranded somewhere at the wrong time and place.
Sam2000
10-05-2006 10:21 AM
Skyline411
11-06-2005 02:21 PM
i've had my car for 4 yrs 3 mos, and it has 48,000 miles on it. should i change my timing belt, etc?
[tri]liament
07-29-2003 09:24 PM
