98 audi a4 2.8
hey you guys me again im still confissed with this timing bell issue i cant get this car to start couse timing sa you know when i changed the cam tensioner gaskets and seal i didnt marked the cams i just took the gears off withuot marking them now i can not set the timing right so my question is what do you set first the crank shaft then rotate cams to tdc couse when i set the crank i can not rotate cams they only go about 180 degrees so and if i move the crank then i can adjuste the crank i dont know what to do here so please i would like to knwo what to do here i really appreciate your help and thanks i hope you understand what im trying to say please help !
vtraudt
03-30-2011 11:34 AM
MB The Body
07-13-2007 07:55 PM
