A4 2002 Water Leak Driver side
Hi,
As the title stated after rain I have water on the driver side floor. Anything you guys suggest that I can do? I don't see any more materiel that is also wet and I have no clue where it's comming from...
It's only on the driver side...Any DIY??
Anyone?
Anyone?
The plenum water drain tube/s could be clogged with leaves and similar debris, provoking obscure leaks like that. The ECU box to body joint is never submerged under water with proper water drain tube function. Test using a garden hose without a nozzle, directing water into the plenum vertically from above, place hose within ~2" of the plenum floor, pointing down. The drain tube has a rubber "duck bill" one way check valve on the discharge end, trash gets stuck at the one way valve even with a clear drain inlet. The drain tube should flow at least 1 liter/min. (guess-timate)
GuyJefferys
Audi A1
09-06-2015 05:19 AM
bilbo6209
10
09-04-2015 04:07 PM
stormchaser1967
09-02-2015 09:02 AM
