about to change my spark plugs..
If your car is chipped, you should run two temp ratings cooler. There are iridium plugs and the Bosch Super, (3 elec. copper plugs).
If you need these numbers let me know.
jwj500@earthlink.net
i got the ngk 7e's. the car is chipped and i am running larger injectors. i have had these plugs in my car for 2 days now and they seem to be ok. what do you think?
Not sure what temp these plugs are, (your NGK's).
Check to see if they are two temp ranges colder then the stock plugs. If so, you should be fine.
I switched to the Bosch Super, (copper with 3 electrodes) vs the iridium. With software and injectors your producing more heat-
Photoputz83
1.8T Discussion
09-25-2019 04:07 PM
Speec
10-06-2015 07:30 PM
S4intheOC
09-08-2015 12:12 AM
Florida8L
09-07-2015 03:36 PM
