About the musty odor coming from the A/C...it came back (more)
The musty odor came back...called service department and scheduled an appointment for them to take care of the problem. They will perform something similar to the TSB woofpup posted earlier with regards to the "Airsept" procedure.
The Lysol treatment only worked for a week or so.
few minutes with the AC OFF (i.e. in Econ mode) before turning the car off, when you've been running the AC for a while. This helps dry up condensation so that mold won't form in the system (causing the smell).
Why does the brand have anything to do with it? My Merc and my friend's BMW do the same thing if you don't follow woofpup's procedure, as will all cars.
an electronic blower control that pulses the blower after the car is turned off for a while to dry out the condenser (assuming the AC was run for longer than 3 minutes).
However, it sounds like they only do this on an as-needed basis: <A HREF="http://www.gmtcny.com/afterblow.htm">http://www.gmtcny.com/afterblow.htm</A>
Otherwise, the standard rules apply - like phred said, it's common across most cars. Some people even suggest running the HEAT full blast with the AC off for the last few minutes, to dry things faster.
If I turn off the car with the recirculate button ON, it will fall back to FRESH air (not recirc) when I turn it back on....is there a way to make it stay in RECIRC mode all the time?
