ABS 01200 fault code please help
Hi.
I got issue with my wifes car, please help me.
Esp, abs and brake sign flashing. Tested with vcds and the following codes been find.
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
After that I coded the ABS modul, but the steering angle sensor do not comunicate with the ecu, so replaced that as well.
Than the fault codes gone, but a new one come up which is
01200- ABS Valves Supply Voltage
35-00
I checked the fuse, which is ok. Replaced the valve on the ABS modul, but the code still on.
Any idea?
Thank you.
2 Faults Found:
35-00 - -
35-00
Any idea?
Thank you.
Mikey'sS4
VAG-COM Discussion
9
07-25-2011 03:13 PM
4Bidden
01-16-2006 05:39 AM
My2ndS4
08-11-2005 09:50 PM
My2ndS4
08-10-2005 02:44 PM
