ABS wheel speed sensor fault / G47 00283
Old 06-10-2011, 04:34 AM
  #11
VipDesigns's Avatar
Originally Posted by DDMan
It's the only thing really left. There is the sensor, wires, and then the control module. The wires are safely tucked in the fender and there's been no damage to the fender and no stress/pulling on the wires that I can see. Unless there are other things I'm missing and the Bently manual doesn't know about... The ABS control module is all that's left.
Im thinking that may be my issue as well, but wouldnt the vagcom give us an error code for that?
I'm getting really tired of dumping money on this car, I dont mind replacing parts if they are needed and solve the problem, but its aggravating spending time and money and at the end you still have the same issue. (In my case, I mad it worst)
Old 07-14-2011, 03:17 PM
  #12
ruski's Avatar
Well, I have been having the exactly same issue for the last couple of months. Still trying to find a solution.
Old 09-12-2011, 09:14 PM
  #13
ruski's Avatar
Hey guys, just wanted to check back and let you know that I got mine fixed! Finally! At first I changed the ABS left speed sensor and it did no good. After doing some research I took out my ABS module and sent it in to get it repaired. I got it back less then a week later. The ESP and ABS lights have been off ever since. I did it through www.cheapabs.com Legit place, also saved me a ton of money compared to buying a new ABS module Thanks.
Old 09-19-2011, 07:39 AM
  #14
lyleswk's Avatar
Do you know specifically what they do to it? Guess I could follow the link, but am feeling lazy.
Old 07-16-2013, 04:49 PM
  #15
troywu's Avatar
Default ABS speed sensor supplier
Anyone who need ABS speed sensors in large quantity, please contact me by sales1@china-softec.com
Old 08-27-2015, 04:51 PM
  #16
axelchief's Avatar
Hello there;
Similar/more problems to 1996 A8 2,8: First the ABS activated below may be 3 mph, making the pump run, and the wheel sticking - front left. Was to a workshop, they determined the ring was OK, but the sensor needed to be replaced, they said. I got one from China (part # 4D0 927 803) (original was Wabco 441 032 721 0 (33.95 PRI 001). Price from China was USD 60.00. I replaced the sensor with the new one, tested: Now the slow speed activating has disappeared; but the ABS do now activate at app. 25 mph, making the pump running. And the pump are running for a while, making ABS failure alarm, and ABS trip. I guess I tomorrow will replace the original one again, after has cleaned from a little dirt. Did someone have the same problem? May be I need to replace the hydraulic unit?
Old 08-27-2015, 05:18 PM
  #17
axelchief's Avatar
Actually, I buyed this first generation A8 for test. After some while with the BMW E38 740. The car is wonderful to drive, but is full of failures: The ABS, start problems (weak key-signal), AC compressor has bad bearings, the rear speakers do not work (Nokia), leaking oil pressure switch. I gave a low price, but now I would likely quite it for nothing, and buy a ewer one a new chance.
Old 08-28-2015, 01:11 AM
  #18
axelchief's Avatar
Folks! I replaced my drivers side sensor yesterday, more or less same failure came up (abs activated from low speed). Was my fault, I checked today, and the sensor missed 3 mm from correct position. Should be 24 mm from top of sensor to hub. Now the ABS system seems to be OK, Thank You!
Old 02-13-2018, 12:42 PM
  #19
momomecanicas's Avatar
Default quick fix for abs module
hey momo audi volks specialist here, if u havent fixed ur issue or if anyone is curious to know how to fix this issue reply back i will help u find the excat solution for your abs issue. i just did one today and i was reading this, so i figured why not let you guys know how i fixt it in 5 min.
The following 3 users liked this post by momomecanicas:
Aramis Deveruex (02-08-2021), Aussiebrat (02-28-2023), gussti (10-06-2020)
Old 11-12-2018, 10:44 AM
  #20
Ainsley Goodwin's Avatar
CAN YOU HELP ME PLEASE? I’m having same issue I’d love some help with it.
Sorry im jumping on an old thread, hope you can still help me.
Quick Reply: ABS wheel speed sensor fault / G47 00283
