Actuating Motor for Temperature Flap: Right (V159)? Anybody know what this means?
01810 - Actuating Motor for Temperature Flap: Right (V159)
41-10 - Blocked or No Voltage - Intermittent
Thanks a lot.
Thanks a lot.
working. Have you noticed that the right hand side climate control isn't working properly? If it's intermittent it may not be noticeable.
Your a/c system/ducting up behind your dash board has internal flaps, for directing air, in and around the cabin. These flaps are controlled by small electric motors or servo's.
Your V159 motor maybe be bad, disconnected or stuck.
If you have the Bentley manual, it has pictures of the V159, and its location.
Also-<ul><li><a href="http://search.audiworld.com/?q=v159&u=&s=all&cat=010022&db=199 9-01-01&de=2008-07-09">http://search.audiworld.com/?q=v159&u=&s=all&cat=010022&db=199 9-01-01&de=2008-07-09</a</li></ul>
I had a similar fault code (can't remember the exact fault code I had) quite a while ago. I removed the motor assembly, sprayed some electronic contact cleaner into the potentiometer connected to the motor & rotated the potentiometer back & forth several times. Cleared the code & it hasn't reappeared. YMMV.
Had same issue and was able to clear it by using Ross Tech to go to AC module - basic settings and having module perform a recalibration. took 2 minutes to move all flaps to min and max and find new zeros and then the noise and codes have been gone for 2 days now!
How do you get basic settings to do a recalibration of the flaps??
levansula
24
01-26-2021 04:02 AM
hardipk5
10-02-2015 08:32 PM
