to add a 4ch amp I would need hi-low converters for the front channels
AudiWorld Expert
and run them back to the trunk?
tap the remote for the stock amp into new amp
and for the sub i need another converter to tap into stock (non bose) amp?<ul><li><a href="http://cgi.ebay.com/Stinger-High-Power-Fixed-Line-Output-Converter-SLOC_W0QQitemZ170106185245QQihZ007QQcategoryZ50552 QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem">s omething cheap like this?</a></li></ul>
you need the RCA output adapter, which connects to the HU and gives you 4 (or 6) channel RCA outs plus a remote turn-on lead. Use that to feed your 4-ch amp, and then pass-thru to the sub amp. No need to mess with hi-low converters or tap into any of the stock signals if you are going to amp all channels
AudiWorld Expert
and what are those for? remote?
are all the wires inside the 6 pin connector for the 6 sound channels?
there should be front L/R RCAs, rear L/R RCAs, center and sub RCAs, and a remote turn-on wire. I have the older 4-channel version, which I've been meaning to install for about 4 years now =P but I've tested it and it works well.
I had originally planned to replace speakers and amp them, but ended up just throwing a small sub in the trunk. I'll do it at some point, when I run out of other mods. SQ went up significantly just by installing the RNS-E
xkahn
02-08-2018 10:43 AM
LaserSVT
64
01-19-2016 04:26 PM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
