Aftermarket Oil Feed Line for K03/K04?
Is anybody using some kind of aftermarket oil feed line for K03/K04 turbo? Something like a braided line with some adapters to fit turbo / oil cooler fittings and keep the same flow/pressure as OEM. Thanks
I have researched the subject a lot lately...
but more along the lines of swapping for a GT3071R.
Anyway, the following information can be useful to you.
The stock oil line attaches right here at the oil cooler.
<img src="http://i132.photobucket.com/albums/q33/x1rider/turbooilline1.jpg">
and enters the turbo here.
<img src="http://i132.photobucket.com/albums/q33/x1rider/turbooilline2.jpg">
You can buy an adapter for the oil cooler that will have a -4AN nipple on the other side here.
<a href="http://www.034motorsport.com/product_info.php?cPath=40_52&products_id=953">1.8T oil feed adapter></a>
You can build a feed line with a -4AN braided stainless steel hose and hose ends available here.
<a href="http://www.holley.com/categories.asp?division=Earls">Earl's perfomance plumging></a>
Now, I'm not sure about the connection at the turbo because I researched for a GT series turbo which requires a restrictor, you could contact 034 and ask them what you need to feed into a K03, they'll know.
Good luck.
I also researched the oil drain, water in/out lines if you need more info.
Good luck.
You can get oil feed and oil return lines from ECS...
They are braided lines. I got new ones from ECS before putting in the K04. Since the K03 had 93K miles on it, I didn't want to risk any potential sludge or buildup damaging the new turbo by using the old lines. May not be necessary, but was just an added precaution for me.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=1.8T&mod el=B6%20A4&submodel=Quattro&category=Engin e&subcategory=Turbo">Oil Feed and Return Lines (at the bottom of the page)</a></li></ul>
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
