Alignment question! please read!
Hey guys, my left-rear tire wore out badly
and just changed four tires (had to change anyways)
However, I got alignment not even 1 year ago and car goes straight (no problem)
Do I need only rear alignment?? back of my car is tilted toward left side. gap between tire and the fender on my left side is much much smaller.
Or, do I have to get four wheel alignment??
let me know Thanks!
(It has been more than two years in AW and still don`t have sig lol)
let me know Thanks!
Maybe you should check your suspension on that side. I dont think bad alignment would cause the car to lean to one side. Busted suspension will cause bad alignment/ uneven tire wear
Your car has adjustments at all 4 carners, so yes, you need a 4 wheel alignement. And you need to be having the car aligned at least once a year.
If you have any suspension mods (i.e. adjustable length control arms, coilovers, slotted/threaded, etc.) part of optimizing handling includes corner balancing. If you have any adjustments, your objective is to balance the front left/right rear, left front/right rear for equal weight. Maybe you should check that or rear camber, thrust angle is out of whack.
scottnybottny
09-05-2015 01:35 PM
stormchaser1967
09-02-2015 08:48 AM
