Are all hubcentric rings the same?.......................
Old 10-06-2005, 01:53 PM
MuRaN0Daddy's Avatar
Default Are all hubcentric rings the same?.......................
I used the ones that Edge sent w/ the Fliks, but I think I'm getting a little vibration from the front drivers, not to the steering wheel, but noticeable. Sort of goes away after driving for a while.
anyone?
Old 10-06-2005, 03:50 PM
ILMA_Revo_Stage_2+'s Avatar
loose lugs maybe?
Old 10-06-2005, 03:52 PM
needforsleep's Avatar
Default They should have fit very snug. It might help to take the wheel off and inspect it....
Also check to see if a wheel weight fell off.
Old 10-06-2005, 04:03 PM
Uhhhhhhhhhhh....a wheel weight????
I have them all torqued to 75
Old 10-06-2005, 04:15 PM
Default those little thingys stuck to the inside of the wheel...used when balancing the wheel...
a lot of times you can see where one was once stuck and has fallen off, but in your case you may not see anything since the wheels are new (weights haven't been on there long and probably haven't left any witness marks).
Old 10-06-2005, 04:16 PM
Default wooa, I thought the torque specs were 90ft-lbs....
I torque mine to 100ft-lbs.
Old 10-06-2005, 04:18 PM
Default I just found this from alldatadiy, which pulls data directly from the Bentley repair manual...
<b>Installing wheels </b>
To install a wheel, screw in all wheel bolts uniformly by hand.
Tighten wheel bolts, e.g. with a 4-way wheel wrench, to 30 Nm in diagonal sequence.
Lower vehicle to floor and tighten all wheel bolts in diagonal sequence to specified tightening torque. Tightening torque <b>120 Nm</b>
Old 10-06-2005, 04:21 PM
120NM is ~89ft-lb (OEM spec)
Old 10-06-2005, 04:48 PM
Default by hand or with an air gun?
my torque wrench only goes to 75. should I approximate 90?
Quick Reply: Are all hubcentric rings the same?.......................
