Any idea on how to remove the interior aluminum trim (1.8)? Would a shop manual have this info?
Ok, there are four bolts for that piece (more)
You "carefully" remove (unclip) the plastic trim above the center console - it's the piece above the cupholder/ESP/etc section (there are two bolts behind this piece for the trim). Then, pull off the right cover of the dash, which is the side panel that faces the passenger side door (there is one bolt behind this piece for the trim). Now, the fourth bolt is to the upper right of the steering column, below where the trim ends at it. It looks like you have to remove the plastic panel to get to it, but I'm not positive from the illustrations.
Andy Hedin
03-01-2001 04:42 PM
CW
08-03-1999 08:28 PM
