any ideas why my ESP light turned on by itself while I was making a road trip?
and I couldn't turn it off. Pulled over to a nearby gas station and shut off the engine. When I restarted the car, it cleared. What does ESP do exactly?
TIA
TIA
Or was it the orange triangle/exclamation point light?
You can disable the ESP system by pressing the ESP button on the dash above the radio.
ESP (electronic stability program) uses the ABS senors, a yaw rate sensor, accelerometers, throttle position senors, etc. to determine whether your car is proceeding on its intended path. If, for example, you pull a full-lock turn on ice, the car will understeer and not rotate at the appropriate rate, indicating slippage. The ESP system brakes the appropriate wheels (in this case, the inner rear wheel) in an attempt to bring the car back in control.
It prevents understeer and oversteer.
Some manufacturers include both an "ESP working/ESP deactivated" light and an "ESP malfunctioning" light. Others use the same light for all three indications.
Zenith - you probably knocked the switch and shut off the ESP system accidentally (which switches on the light). When you restarted the car, it reenabled the system.
it turned on by itself and cannot be turned off, as I tried to press the ESP botton several times while driving. I dont usually get this light, last time I recall is last summer.
Just wanted to know if it is "safe" to drive with this abnormality. (and I just relocated so probably not going to visit dealer soon)
