Anyone got the lowdown on front door panel removal ?
Woofpup posted a pic some time ago on how to do it but....
it's pretty simple,
1. Gently pry off the alum.(or wood) trim from the "hinge" side of the door first. The other side has a sort of hook thing.
2. Once the trim is off you will see a few phillips screws to remove.
3. On the drivers side there are 2 screws in the middle of the door panel (under that big ugly cap) and on the passenger side under the grab handle part you will see a hole. Peek in and you will see 1 screw there.
4. Along the bottem edge in the middle there is one black screw.
5. Once your certain you got all the screws out give the panel a good yank then pull it upwards. The top edge is kinda hooked over the door.
Hope this helps. What are you doing anyway, new speakers?
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
Zumkopf
09-10-2015 05:23 AM
Florida8L
09-07-2015 05:22 AM
ajg617
09-06-2015 07:23 AM
