anyone has injectors in there cvt? If so who sells them ?.more....
Hi,
I know apr has a new chip for the cvt, would you know if they have injectors to? If so I will probably do both.
thanks
thanks
<center><img src="http://www.redpulsar.us/~coldfusion/film15/injector3.jpg"></center><p>...enough torque to trip the limiter on the CVT. Your fuel flow will then cut and the engine will coast down until it's safe to get the fuel flow turned back on. The injectors from the 190 HP BEX engine flow slightly more and will maximize your torque without going over. You'll still need to get your ECU tuned for them.
Have you gone with a dual SMIC or a FMIC yet? Otherwise you'll just be pumping hotter air with an injector upgrade and losing power - kind of like chasing your tail.<ul><li><a href="http://clam.rutgers.edu/~dreadsct/resell/1.8T_injectors.htm">Audi 1.8T Injector Information</a></li></ul>
I checked the numbers on that list. they are the euro tt from 1998-2000
the part# is 0 280 155 892
it is 1 digit off the TT225, and they list the TT engine cap at 210. must be a little lower flow than the 225 injectors.
Now, which part number are the MTM ones?
Audi A4 AUDI 19" S-Line Wheels for sale
WillSav
03-19-2016 04:44 PM
Audi A6 2003 allroad 2.7t for sale in AZ
blackjulia
09-27-2015 09:37 AM
