anyone have any repair info (bentley?) on rear driver side window regulator?--desperate
i've searched everywhere and there is pretty limited info.
thanks for any help..
greg
greg
Usually when window regs break, you have to replace'm to fix'm.
Replacing involves dismantling the door, R&R of the reg, and then adjusting the reg & door so the window functions properly.<ul><li><a href="http://search.audiworld.com/?q=window+regulator&u=&s=all&cat=01002 2&db=1999-01-01&de=2007-02-22">http://search.audiworld.com/?q=window+regulator&u=&s=all&cat=01002 2&db=1999-01-01&de=2007-02-22<
including removal of door trim etc. if there's a "rear driver side" specific version of that info, all the better. something was posted a long time ago but images are dead, and the directions are kind of lost without them.
thanks a ton..
thanks a ton..
all the articles that come up when searching have information that is incomplete and/or have broken links to images that would otherwise explain things. (thus red X's)
are you saying you found an article that explained how to go about replacing the regulator?
CPLYONS
09-07-2015 07:19 PM
stormchaser1967
09-02-2015 09:02 AM
Touge.ca
Canadian Discussion
09-02-2015 01:28 AM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
