anyone have feedback problems from their phatbox?
Old 10-11-2005, 11:42 AM
philip200qt's Avatar
Default anyone have feedback problems from their phatbox?
I just got the audi cd changer cable in today, got it all wired up, plugged the phatbox in, and with the volume all the way down there's an annoying HUMMMMMMM sound, fairly loud.
I've checked over the wiring at least 5 times, nothing appears to be out of place, and the hum goes away if you unplug the data cable from the back of the Pbox, so I'm wondering if mine isn't defective :-\
the only oddities in the harness are the violet wire not hooked up to anything, and the "RS" wire on audi's diagram that isn't referenced.
Old 10-11-2005, 11:58 AM
QuattroRocket's Avatar
Default Love mine, but I would like ...
A little more volume output from the system.
And a femail voice prompt.
Old 10-11-2005, 12:30 PM
Default :)
did you read the question? LOL
thanks for the input. I notice mine isn't terribly loud either. And that digitized voice is awful, I agree.
edit: upgrade the firmware, you'll get a female voice for the recorded parts, like "browsing artist" and a male voice for the parts it reads to you. Seems a little better, but didn't solve my problem. Guess I'll call PN support.
Old 10-11-2005, 12:36 PM
Default I also do not believe this to be correct
<center><img src="http://www.audicrazy.com/phatnoise/radioconnector.jpg"></center><p>
I don't believe those pinout are correct, unless I'm on crack, I've traced out the round audi connector using a diagram found here, and for example pin 10 is the switched 12v, not a ground.
if I had miswired this, I'd have a direct short and more problems on my hands than a little buzzing, and the phatbox is obviously grounded (it tests OK as well)
so something is up, the audi OE changer cable instructions connect the long brown wire to pin 10, which if those are correct is a ground and wouldn't work. ugh. My head hurts.<ul><li><a href="http://www.audicrazy.com/phatnoise/radioconnector.jpg">phatbox howto</a></li></ul>
Old 10-11-2005, 01:01 PM
Teknic's Avatar
I have a female voice promt with mine. Maybe you need to upgrade your firmware.
Old 10-11-2005, 01:10 PM
timps's Avatar
Default Re: I also do not believe this to be correct
Pin 10 is ground on my radio it is possible your phatbox could be grounded through the speaker or the cd ground pin 18 the diagram looks like the sticker on the back of my radio if all nine wires are not used you will have problems
Old 10-11-2005, 01:21 PM
timps's Avatar
Which radio do you use the wiring is different between chorus/symphony I and chorus/symphony II the diagram relates to chorus/symphony II
Old 10-11-2005, 01:24 PM
it's an RNS-D unit, I guess I hadn't considered that, but on the audi supplied directions for the cable, the pinouts for both are identical, I'm really not sure why they draw both other than the lack of harness IV
Old 10-11-2005, 01:25 PM
you're right, see my edit below.
Old 10-11-2005, 02:00 PM
Default Yep... ID-10-T error. problem solved.
basically what happened is I accidently popped the yellow pin in the brown/black spot, and couldn't get it out again, so I just figured at the end of the cable I'd cut and jumper them yellow to brown and brown to yellow, well, that something happens mid cable with the two browns and I had the yellow to the wrong brown, which is why I thought that pinout diagram was wrong, I had the +12 switched (yellow) to the ground (brown).. dumb mistake, that's what I get for taking a shortcut.
I kept tracing the wiring through the male connector to the pins at the HU and that's why I thought the ground to pin 10 was off, so really the thing wasn't completely grounded.
Quick Reply: anyone have feedback problems from their phatbox?
