Anyone have instructions on changing the coolant neck on a 1.8T....
It's the part on the backside of the engine near the head that's been known to leak down onto the transmission bell housing. I saw the tech article here, but it looked like it was for a B5 as it did not have all the plumbing and wiring in the way that my car has. Anyone know what I have to remove to gain access to it - or is there a way to sneak past the stuff that I'm not seeing? To me it looks like I need to remove the rubber crankcase breather hose and hardpipe as well as push some wiring out of the way. Looks like a real PITA to change $20 in parts.
<center><img src="http://images.andale.com/f2/109/101/17613004/1135995789712_ZZZZZZ30117.jpg"></center><p>Just give yourself at least three hours. To make things a little simpler get yourself a remote coolant hose pliers. Looks something like this.
normally not accesible to your hands and/or regular pliers. The coolant flange has one specific hose sticking out towards the right side (looking at engine front to back) that is almost impossible without a tool like this. I did it the hard way, but it cost me an extra hour and some slight modifications to my regular set of pliers to get done. With this, it's a breeze.
Was this your experience too? Were there any other parts that I can remove to make things easier?
some zip ties with you, be prepared to cut a few of them to loosen some wiring over and around the valve cover.
$200 in labor to change $20 in parts! You wouldn't happen to have the P/N's for the coolant neck and a new coolant temp sensor? I might as well change the sensor while I'm in there.
