APR 1+ owners!!!!!!........
I have an APR 1+ ECU/ injectors and a testpipe.... with everything i assume im at 235 hp and 295 lb/ft. of torque
- tell me what you guys think....thanks
And varies with weather/temps and numerous other effects. You can get it dynoed, but even then, there is a measure of uncertainty of the accuracy obtained. Additionally, unless the engine is mounted on a test cell dyno, the crank hp will be a guesstimate based on the measured wheel torque @ some range of rpm.
I am guessing more like 220/270. When my commission check comes in after xmas recoop I am going to my neighborhood dyno. And possibly a test&tune at Moroso.
I don't think a test pipe will give you an additional 20 ft. lbs. of torque, but I've never seen back to back testing on them to know for sure.
Keep in mind those numbers are probably the best APR got, and since with multiple samples, you'll get a distribution of results, which means half are below the average. You just have to hope you're well above average. :-)
Fixeroh
Audi A3 / S3 / RS 3 MKII
09-09-2015 02:37 PM
ECS Tuning-Audi
09-09-2015 01:05 PM
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
