APR K04 kit = $2300, Revo K04 kit = $1600; why do the prices vary so much?
#11
revo software to make a custom map for a ko4 turbo. Revo stage 2 means injectors and software flash for use with the stock ko3.
I'm not an expert but, from what I understand, Each tuner can alter the revo software maps for a given application. Lets say you found a turbo and a manifold that would bolt up to a 1.8t motor but there wasn't any software out for it. If you had the revo package, you could make your own map for your ecu.
But to do this, you would need to be an authorized dealer for revo and spend the boat load of cash to get whatever you need to use and customize their software like ecode or pro-imports does.
#12
thing you can do with SPS3.
Eurocode had custom software written by REVO for E05 turbo, then later that software has been fine tuned for K04 by Nick.
#13
James said he flashed my car with Stage 2 software. Then he tuned it...3 gear from low RPMS to redline as he adjusted boost and timing while monitoring the CF's. I guess I have a custom map.
Hmm...I'll need to call him to confirm this.
#20
I have the stage 2 revo program with tweek boost/timing and my car is running great with the logs that i did.
I have seen dynos from the eurocode file vs what the other revo dealers get, not much difference other than people falling for ecodes marketing.
