APR vs. AWE
I'm new to the Audi scene but not to upgrading cars in general. I know that alot can be found on forum sites like this one, so I have a few questions I want to throw out there (and many more if I get a good response from these). I have an '03 Audi A4 Quattro, 1.8T. I was looking at companies that made performance parts and came across two that I thought were the cream of the crop considering all that was out there. One of the quickest and easiest bangs for the buck in these cars seems to be the ECU and it's tuning. In looking at the AWE flash (GIAC flashloader chipset) I can notice the quality but the performance isn't what the APR Stage 1+ can deliver. I'm sure some of you have experience with either company. Can anyone give me some advice as to why I would choose the GIAC or the APR Stage 1+ and feature some pros and cons on both types? I was also looking at the diverter valves, exhausts and intakes. Is there a major difference between a diaphram diverter and a piston diverter valve? And I heard the sound clip on the AWE exhaust... is there a sound clip of the APR Stealth exhaust (I hate loud, tin can exhausts)? Are there any other options other than the Carbonio intake out there? I know this is alot to ask all at once, but it took me a while to actually find a forum that I thought would be helpful and I tried to do as much homework on various sites and performance parts before I came on here and seemed like a noob. I appreciate any feedback you guys can give. Thanks.
Former Vendor
Thanks for the response, I appreciate it. Yes, I understood with the APR 1+ that I would need injectors. The GIAC system that AWE sells also has that option, but at a lower hp and tq number then APR's chip. Now that I have at least one person's attention... even though both websites tell me that the Audi will need a new clutch with a chip and exhaust... are they saying that to make me buy a clutch or is that norm? Would I need to look into clutches as well (70k miles on the odometer) and if I do need to look, what clutch or clutches are the recommended norm? Thanks again for any information.
if you are going to be very delicate on the clutch then oem might last you but it's weak. If you want to pounce on it then get a OFE SS stage 4 clutch, you will be able to lunch from whatever rpm you want.
BUT if you are going with 1+ I would recommend FMIC as the tiny OEM inter-cooler gets heat soaked VERY quickly (in summer one stomp on the gas and you are heat soaked) and you loose major power when that happens!
On the other hand don't bother with exhaust unless you are planning to go with a big turbo later. OEM flows more than enough for stage 1+.
Same with intake, don't bother unless you are planning a big turbo down the line. REAL OEM filter has a very good flow, avoid man/mahle/fram etc.
and for the cost of an exhaust, get some forged light weight wheels and you will be happy
good luck
good luck
Former Vendor
A clutch isn't necessary with just stage 1+, unless you anticipate you'll be launching the car hard.
For everyday type driving the stock clutch will hold just fine.
mine was slipping under full boost in fifth on straight, between 2800 and 3600 rpm. when my mechanic took it apart he said that the oem was still in good shape and not glazed/burned
2004 A4 1.8TQ
