Audi B6 A4 1.8T BEX Misfire Under Load
1 Post
Hi all
I am having a strange issue with my A4 where under heavy load such as full throttle in 3d or 4th gear from around 2000 rpm she will start to cut out/splutter at around 3000 rpm and feels like a misfire. It is strange because if I run her on her normal stock map I cannot replicate the misfire but as soon as I run even a basic Stage 1 REVO map she misfires. Obvious causes are plugs, coil packs, leads or injectors but what gets me is she runs fine on her stock map...
Any thoughts? I have yet to run logs on her so that will be my first port of call...
Cheers
Nic
Cheers
Nic
1 Post
Not yet, will do so this weekend, just wanted to get input from otehrs as I found it strange that she will only misfire under load with Stage 1 software loaded but won't with stock software. I realise that boost, fuelling, timing, etc are all changed so my only guess is that the Stage 1 software merely exposes a current weakness or issue that the stock software does not...
1 Post
I haven't spoken to them yet, want to do soem basic checking myself first as I am not convinced it is a software issue. I have a friend who has the same car although the sedan version and his is running 100% on the same REVO software...
1 Post
http://www.vwclub.co.za/phpbb3/viewt...?f=11&t=119856
OLD FART HERE,
nice something to start with,if I can help let know !!
DAN B.
SUNCOAST VW AUDI,
PM me next time,
let me know what u come up with,send pic of engine bay on the A4,
DAN B.
SUNCOAST VW AUDI,
PM me next time,
1 Post
Thanks for the offer of help
1 Post
So, finally got round to doing some testing as I managed to get hold of some older, fully working coil packs from a friend. Replaced coil packs on two cylinders, closest to the firewall, loaded my Stage 1 REVO map and the misfire is gone. She still pulls a bit of timing in warmer temperatures but the horrible misfire is gone...
So, new coil packs are in order, then I'll get my colder temperature range plugs in, have a new Forge TIP lying at home as well and need to get an intake and DP as well...
ilkoUSP
10
04-21-2008 06:47 AM
Avantgarde
18
04-20-2005 09:04 AM
MasterBlaster
35
02-02-2004 04:20 PM
