Audi Cabriolet B6 fires then cuts out after 2 seconds.
My 2.4 Audi A4 B6 cabriolet decided to not start. The car fires up then cuts out after about 2 seconds, most of the dash is dead & no warning light shows that the car has been mobilised. The battery is about a year old and has been fully charged.
A mobile mechanic scanned the car for faults, cleared the stored codes and then done a re-scan, the results are below. Any help with this issue would be appreciated..
Chassis Type: 8H - Audi Cabrio B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
65 67 73 75 76 77
VIN: WAUZZZ8H13K004446
Address 01: Engine Labels: None
Part No SW: 8E0 909 552 M HW: 8E0 909 052
Component: 2.4L V6/5V G 0003
Coding: 0011504
Shop #: WSC 00672 785 00200
2 Faults Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 008 - Implausible Signal
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04495
Shop #: WSC 00953
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 C
Component: A4 Klimaautomat 1012
Coding: 00100
Shop #: WSC 00672
4 Faults Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
00474 - Control Module for Immobilizer
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00672
6 Faults Found:
79-00 - Please Check Fault Codes
01312 - Powertrain Data Bus
01800 - Light Switch (E1)
27-10 - Implausible Signal - Intermittent
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655
Component: Airbag 8.4EC 1005
Coding: 0011104
1 Fault Found:
004 - No Signal/Communication - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 00672
3 Faults Found:
01304 - Radio
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6184
1 Fault Found:
Address 46: Central Conv. Labels:
Note: Excessive Comm Errors
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H11 X023
Coding: 00005
Shop #: WSC 00065
3 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
3 Faults Found:
65 67 73 75 76 77
Coding: 0011504
2 Faults Found:
Coding: 04495
Shop #: WSC 00953
2 Faults Found:
35-00 - -
Coding: 00100
Shop #: WSC 00672
4 Faults Found:
Coding: 00001
Shop #: WSC 00672
6 Faults Found:
Coding: 0011104
1 Fault Found:
Coding: 02041
Shop #: WSC 00672
3 Faults Found:
01304 - Radio
1 Fault Found:
Coding: 00005
Shop #: WSC 00065
3 Faults Found:
Coding: 00005
Shop #: WSC 00065
3 Faults Found:
joe@devitto.com
05-24-2017 02:26 PM
