backlight on instrument panel w/ lights off?
all right, am i just delusional, or isn't there normally some kind of illumination on the instrument panel when you have the lights off? Specifally the speedo and tach, and the needles on the fuel gauge and temp. Just a little bit, enough to be able to read it easily in the shade when you don't have the lights on?
after 4.5 years of driving this thing, you'd think i'd notice the difference right? I had my stereo code reset and when they did that, it first, knocked off the display of the stereo info in that driver info display, and i could swear that the needles and numbers are way darker than they used to be.
17-Instruments: K1 -- KWP-1281
VAG-COM Works fine.
Tweak:
There are four lighting modes:
Mode 0: Nothing lit until ext. light on
Mode 1: Pointers lit all the time
Mode 2: Scales lit all the time
Mode 3: Pointers and Scales lit all the time
Mode is changed in Adapation Channel 19. Standard value should be 11000 (or something close). The first (left-most) digit is the lighting mode.<ul><li><a href="http://www.ross-tech.com/vag-com/cars/audiB6.html">http://www.ross-tech.com/vag-com/cars/audiB6.html</a</li></ul>
VAG-COM Works fine.
Tweak:
bballfreak
9
04-14-2019 06:59 PM
Cmmartin23
26
08-23-2016 04:44 PM
