bad coil pack wiring, need help ASAP!
Old 06-23-2008, 11:23 AM
  #11
PDX04a4's Avatar
sorry, fuel pump, not just the filter. although ill probably change that out as well.
Old 06-23-2008, 12:06 PM
  #12
nanotech's Avatar
Default Is/was the pump humming?
Humming from back right area of vehicle?
Usually they make a lot of noise before they die. Anyone you can swap pumps with first?
If you do determine it's the pump, you definitely want to do the filter as well, since it was probably the cause of the pump failure...
Old 06-23-2008, 12:52 PM
  #13
PDXA4's Avatar
Default I would tow it to Matrix, you will spend more money in tying to diagnose a issue
And especially stay clear of the dealership...
Parts are also at cost price with Matrix...
Old 06-23-2008, 02:16 PM
  #14
PDX04a4's Avatar
Default i never heard any noticeable humming, i do drive with the speakers pretty loud though...
you should be able to hear the fuel pump as the turn the engine over though, at least that is what i am told.
my roommate also suggested removing the spark plug and coil pack, assembling them and hold the plug to the engine block and turning the engine for half a second to see if the plug sparks or not. no spark = bad plug or bad wiring. the plugs look fine, so more likely it is bad wiring.
does anyone have a copy of the bentley, i would like to know which fuse is responsible for this ignition system so i can check to see if the fuse is blown.
Old 06-27-2008, 09:33 AM
  #15
jeremy_matrix's Avatar
Thanks much Colin!
Old 06-27-2008, 09:51 AM
  #16
PDXA4's Avatar
Default :)
Looks like he got it fixed himself...
Old 07-04-2008, 10:22 AM
  #17
mobsTTa's Avatar
Default Re: bad coil pack wiring, need help ASAP!
Don't panic. Happened to my TT. There is a a fix.
I hope the link works<ul><li><a href="https://forums.audiworld.com/tt/msgs/1419073.phtml">https://forums.audiworld.com/tt/msgs/1419073.phtml</a</li></ul>
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
S4intheOC
09-08-2015 12:12 AM
anticsAK
09-06-2015 05:34 AM
anticsAK
09-04-2015 09:59 PM
aron56
Audi 100 / A6 (C4 Platform)
09-01-2015 12:39 AM
Quick Reply: bad coil pack wiring, need help ASAP!
