Bar to PSI conversion. NOTE: 1 bar = 14.5 psi not 14.7 psi
1 bar = 100 000 Pa
Pa = N/m^2
100 000Pa / 9.807 (Gravity) = 10 196 kg/m^2
10 196 kg/m^2 x 2.20462 = 22 480.06 lb/m^2
22 480.06 lb/m^2 / 1550.003 = 14.503 lb/in^2 or psi
Pa = N/m^2
of guys at shows that have no idea of what they're talking about when relating bar to psi. plus if you look at yesterdays posts their were a few cases of posters relating to bar then coverting wrong into psi.
That the air in the atmosphere as a weight of 14.7 pounds pushing in all directions, 14.7 psi. Yes, a column of air 1 inch by 1 inch by 60 miles weighs 14.7 lbs, at sea level and at a temperature of 15 Celsius (59 F). Also it will support a column of Mercury 1 inch by 1 inch by 29.92 inches in height. I hope that satifies you.
Once again I'm sorry for inducing you in error.
