BAT 1.9T Build
Well the time has come to take advantage of the gt3076 setup that I have been running for the past year. So a couple of weeks ago I started to take the car apart since i'm done with grad school for the semester. All that was done on day #1 was take the front end off, took about an hour.
Parts:
-JE pistons 83mm, 9.25:1 CR, coated skirts
-IE rods
-Calico (sorry can't spell) rod bearings
-ARP head bolts
-ARP Main Stud kit
-amoung other stuff water pump, oil pump, thermastat, seals, etc....
Machine Work: will be done by a shop here in houston that does alot of high power cars from turbo mustangs to turbo hondas.
The Car:
![](http://i58.photobucket.com/albums/g240/dcondado/DSC00413.jpg)
The Turbo:
![](http://i58.photobucket.com/albums/g240/dcondado/DSC00460.jpg)
How it sits right now:
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01091.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01089.jpg)
Plan is that i will pull the engine by the end of the week and hopefully have it at the machine shop since going on Vaca next week. Not sure if i was going to take the engine attached to tranny or just take the engine out by itself... so what do you guys suggest? engine only? or with tranny as one piece? I will update this post as the project progresses.
Day #2
Here is this morning progress: Missing turbo/manifold/alternator/power steering.
Took me about an hour just on the STUPID manifold bolts from underneath, turning those nuts 1/8 turn each time SUCKS!!! so far only one broken manifold stud. Does anybody know what size are those studs? Thanks
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01108.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01107.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01109.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01106.jpg)
Day #3
Well the engine is out [
] took about 2 hrs with my twin brother
Where is my motor?
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01156.jpg)
O there it is......
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01154.jpg)
Ran into a couple of things. I broke that rubber hose piece at the base (you can see it on the above picture, is there a trick to getting the rest of the plastic/rubber out) in the next piece, the one that comes off where the oil filter attaches to and broke the dip stick. also how do i take off the part that the oil filter attaches itself to the block? i took the three bolts that hold it but i could get it to come off is there something else?
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01136.jpg)
Christmas arrived early this year [
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01416.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01418.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01417.jpg)
currently just waiting for couple of more items: pistons, most likely going to build the valvetrain and need to order a clutch... hopefully will order valvetrain and clutch tommorow.
Parts Update
Recieved the clutch(CM FX400 240mm) and valvetrain (ferrea) a couple of days ago, just waiting for the pistons, the first set of pistons, well lets just say a little small but pretty. I should get the correct ones tommorow
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01501.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01496.jpg)
![](http://i58.photobucket.com/albums/g240/dcondado/DSC01499.jpg)
and the small piston...
Parts:
-IE rods
-ARP head bolts
-ARP Main Stud kit
The Car:
The Turbo:
Day #2
Day #3
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Where is my motor?
O there it is......
Parts Update
![](http://i58.photobucket.com/albums/g240/dcondado/piston.jpg)
If you were driving with a bad oil pump, would this affect the turbo in any way? Does the oil pump..
adog4ya
11
04-06-2004 05:47 PM
