Bleed cooling system, is there a writeup?
Hi, is there a write up somewhere on the correct way to bleed the cooling system on a 1.8? Thanks
and slowly increases as the coolant temp goes up. So it doesn't blow cold air at you for one, and two so it doesn't slow down the warming up of the engine.
Don't work on alot of old audis.. but last VW I know to have a cut off to the heater core was the rabbit. maybe a fox or something that carried through the change over..
