Blow dryer noise
Hey guys-
First, thanks for the info. Car is an 03 A4 Quattro 1.8t Just this week did the snub mount(only trouble was getting it on the mount even greased, used a wood working clamp and it popped on) and changed turn signal bulbs. Still need to address the tail seal and the front right axle seal leak. Couldn't think of doing any of it with out your help.
On to the point, just the last couple days, when the car is started there are maybe 30 seconds to a minutes worth of a very high pitched leaf blower - hair dryer type noise. It's not RPM dependent. Runs them stops after about a minute. Thoughts?
Thanks
Gug
Thanks
Gug
My 2 cents: Secondary Air Pump. On the 1.8t, it is located sort of below the turbo. This is a pump that pumps air into the exhaust in an attempt to reduce NOx emissions. They are know for the case cracking and some of the air "leaking" back to ambient rather than going into the exhaust stream.
You might be on to it. The noise seems to be coming from that part of the compartment. In what is probably not a coincidence, the check engine light came on today.
