Boost leak...left side behind engine??? HELP
I cant identify what it is, but i hear what i think is a slight leak when i accelerate. Ive been loving the sound of the spool from the intake and diverter valve but this is a sound coming from the drivers side of the car I feel like it is like right behind the steering column. I dont have any time soon to bring it in, but i was wondering if anyone has had similar symptoms and possibly prepare me for what i have to do. Im sure it will cost a pretty penny. Hopefully its just a hose
Thanks
Sean
Thanks
Sean
how did you find the leak there? I jsut woke up and took a look at the car, i couldnt find any loose hoses or anything. i hope i have the same issue as you did, seems farily simple to fix and inexpensive...so it seems
there was no visible break in the pump but I could clearly hear the air coming out at the junction circled in red.
The pump was fairly cheap and took about 20-30 minutes to change (the stock hose clamps are a PITA to get off and I changed a few check valves in the area at the same time).
if you could hear it with the engine revving, I guess you'd have to try it. I doubt if you'd even hear it with the engine noise, it was easy to find but it was pretty quiet in the garage when I did the boost leak test.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
PoisonBeef
09-04-2015 05:29 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
