Brake lights come on during cold nights
Old 01-03-2008, 08:06 AM
Junior Member
SSLEDGE1234's Avatar
Default Brake lights come on during cold nights
OK, this keeps killing my battery.
When it is very cold out (New England) my brake lights turn on during the night. This is when the car is parked locked and unattented.
It does not make a difference if parking brake is on or off it still does it.
Any suggestions? 2004 B6 1.8QT 6sp manual
Old 01-03-2008, 08:14 AM
AudiWorld Expert
Boston Driver's Avatar
Default Rule #1, don't engage the parking brake on COLD nights unless you must...
...as your parking brake can freeze. As far as your lights go, your brake light switch is probably stuck. SHould be a simple fix, at least it is on the C5 A6.
Old 01-03-2008, 08:16 AM
JayP's Avatar
Mine does the same- bungee cord around the pedal to the steering wheel
Old 01-03-2008, 08:24 AM
AudiWorld Expert
S4iowa's Avatar
Default funny...someone just posted today in B6 S4 about that issue.
something about needing a new brake harness?
Old 01-03-2008, 09:56 AM
Junior Member
Default Re: Rule #1, don't engage the parking brake on COLD nights unless you must...
parking brake does not change it. It does it without it engaged.
Old 01-03-2008, 10:04 AM
AudiWorld Expert
Default I KNOW that, I am just reminding you to avoid usage in cold weather...
...besides, the parking brake has nothing to do with the lights anyway.
Are all brake lights coming on (tails and center brake light) or just the center brake light?<ul><li><a href="https://forums.audiworld.com/allroad/msgs/221052.phtml">today's reminder of why to avoide using the parking brake in cold weather</a></li></ul>
Old 01-03-2008, 10:29 AM
Junior Member
Default Yes, all are on in the middle of the night
Sometimes it is enough to step on the brake pedal and let go, other times I have to start the car and then it is OK.
Old 01-03-2008, 11:01 AM
AudiWorld Expert
Default I still say the brake lgiht switch is at fault...
..it is less than $20 for the aprt, and not too hard to install yourself.
Here is a writeup on how, but for a Jetta IV (I thisnk the process is the same, but the part numbers are probably different...I can look up the part number on ETKA tonight when I get home).<ul><li><a href="http://forums.vwvortex.com/zerothread?id=1158315">X-post to VW Vortex thread</a></li></ul>
Old 01-03-2008, 11:05 AM
Pabblo's Avatar
Default My A4 did this
It was fixed with the brake light switch recall. Well, wasn't a recall on the B6, but it was on the same year Jetta I had. Either way, it's a known faulty part that does what you are mentioning. Never heard any correlation with weather, though.
Old 01-03-2008, 01:30 PM
Junior Member
Default It probably is the switch, please post the part number when you get a chance
I find couple different part numbers online
Quick Reply: Brake lights come on during cold nights
